Thread Title ColoringvB
Konusu 'vBulletin' forumundadır ve guclusat tarafından 2 Eylül 2012 başlatılmıştır.
    Version: 4.0.x ,, Mod Version: 1.01
    This will change your thread title colors.
    Screen-shot is attached with installation text file.
    DEMO: Screenshot and also >> LIVE DEMO
    1.01
    Strikeout the Closed thread.
    Change Hot Thread Color.
    Change Sticky Prefix.
    Change Poll Prefix.
    1.00
    Change Sticky Thread Color
    Change Closed Thread Color
    Go to Admin CP > Styles & Templates > Search Templates
    Search for Additional.css
    Open it for your style most likely it will be empty.
    ADD:
    PHP:
    .sticky a.title {colorgreen;}
    lock a.title {colorredtext-decorationline-through;}
    hot a.title {colormaroon;}
    and Save it.
    Note: If you do not want the StrikeOUt line on Closed/locked Thread then remove text-decoration: line-through; from .lock.
    It will make your Closed Thread title color RED, Sticky thread color Green, and Hot thread will turn into Maroon color.
    OR
    You can choose color of your liking.
    _______________________________________________________________________________________________________________
    If you want to change the Prefix Sticky:
    Go to Admin CP> Lanuages and Phrases > Search in Phrases
    Search for sticky_thread_prefix Select Phrase Variable Name Only then click edit
    You can write anything in that for example if you want Sticky: to be bold then write
    PHP:
    <b>Sticky:</b
    you can use any basic html code.
    __________________________________________________________________________________________________________________
    If you want to change the Prefix Poll:
    Search for poll_thread_prefix Select Phrase Variable Name Only then click edit
    You can write anything in that for example if you want Poll: to be bold then write
    PHP:
    <b>Poll:</b>
Benzer Konular - Thread Title ColoringvB
