Trt dünya kupası biss keyleri
Konusu 'Biss' forumundadır ve guclusat tarafından 9 Haziran 2010 başlatılmıştır.
    TURKSAT 3A
    12688 V 5000 3/4 (DVB-S2/8PSK & MPEG-4)
    { TRT HD }
    B: { Name Space } : 01A40000
    B: { Transport ID } : 0041
    B: { Network ID } : 002A
    B: { System CAS } : BISS
    B: { Cas ID TYPE } : 2600
    B: { Provider ID } : 000000
    B: { Service ID } : 0001
    B: { PMT PID } : 0020
    B: { ECM PID } : 1FFF
    B: { Video PID } : 0065
    B: { HEX KEY } : 1000000000000000
    TRT HD (42°E)
    CAID 0x2600, SID 0x001, VPID 0x065, PMT 0x020, PROVIDER 0x00000
    CW0: 10 00 00 00 00 00 00 00
    CW1: 10 00 00 00 00 00 00 00
    For CCcam & Newcamd (constant cw) :
    D 2600:000000:0001:0020:1FFF::10 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 #TRT HD (42°E)
    For Mgcamd (softcam.kèy) :
    F 00011FFF 00 1000000000000000 ;TRT HD (42°E)
    F 00011FFF 01 1000000000000000 ;TRT HD (42°E)
    For Evocamd (keylist.txt) :
    B 0001 00 100000000000000010000000000000 00 ;TRT HD (42°E)
    For Camd3 Version :
    2600:000001:000000000010000000 0000000010000000 00000000 ;TRT HD (42°E)
    For incubusCamd (softcam.kèy):
    X 0001 1FFF 100000000000000010000000000000 00 ;TRT HD (42°E)
    Gbox Softcam Biss Cfg :
    0: { 26 00 00 01 { 10 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 }} #TRT HD (42°E)
    For SCam Constant DW (older.cvs):
    C: { 01A40000 0041 002A 0001 0065 { 100000000000000010000000000000 00 }} ;TRT HD (42°E)
    For SCam Constant DW (newer.cvs):
    For SS2 :
    TRT HD=100000000000000010000000000 00000
    For Diablo Cams (fausto.kèys):
    2600:000001:FF:06:[ 100000000000000010000000000000 00 ] ;TRT HD (42°E)
    2600:000001:FF:07:[ 100000000000000010000000000000 00 ] ;TRT HD (42°E)
    For T-REX & Dragon Cams (dcw.txt):
    2600 0001 0065 100000000000000010000000000000 00 ;TRT HD (42°E)
    For GigaTwinCam (softcam.kèy):
    X 2600 0001 0065 100000000000000010000000000000 00 ;TRT HD (42°E)
    For Humax (kèy.bin):
    3190 0120 100000000000 ;TRT HD (42°E)
    Türksat 42°E
    11919 V 24444 3/4
    0x001fff 1000000000000000
    0x001ffe 1000000000000000
    DWC : 100000000000000010000000000000 00
    TÜM CİHAZLARA GİRME YÖNTEMİ
    Next 7500 cıs serisi
    provider:011919
    keydata:0E
    key:1000000000000000
    Next 2000 serisinde TRT Biss key girmek
    Biss ID : 0 x 1 f f e
    Freakans : 11919
    Symbol Rate : 24444
    Polarizasyon : VER
    KEY :10 00 00 00 00 00 00 00
    Vestel dvb 3600
    1FFE-01-10000000000000
    Vestel dvb 840 ci
    001FFE 00 1000000000000000
    Dreambox icin
    F 00011FFF 00 1000000000000000 ; TRT 1
    F 00011FFF 01 1000000000000000 ; TRT 1
    B 11919:24444:V 1000000000000000 ; TRT 1
    Kaon Tabanlı Cihazlar İçin
    000000 00 1000000000000000
    benjamin dsr 8000 10 00 00 00 00 00 00 00
    8280 ile biss menüsü açılıyor.
    goldmaster 76100
    ff - 10 00 00 00 00 00
    Taplin serilerinde
    1FFF 1000000000000000 ; TRT 1
    Redline 10 csx için
    trt 19919 - V - 24444 Biss 00 1F FF index 2A Key 1000000000000000
    Yumatu IQ - Serisi için
    2600 000001 11919 1000000000000000
    2600 000003 11919 1000000000000000
    Humax 5400 için
    Nba tv keylerini siliniz.Eski trt şifresindeki caıd değerlerini 1ffe olarak değiştiriniz.Daha sonra 11094 H 24444 frekansı ya da diğer 11919 v 24444 üzerinde 30 sn kadar bekleyiniz.
    amstrad 16100 plus
    002600 00 10 00 00 10 00 00 00 00
    Goldmaster serileri için
    TRT yayınları 2 frekans üzerinden verilmektedir. bu frekanstaki (11919 v 24444) yayınları çözer.
    TRT 1 VE TRT 3 için: Biss ID: 0×1FFF (eğer 6 haneli ise 0×001FFF),
    Kod Değeri: 1000000000000000 (eğer 12 hane varsa 10000000000000)
    4000-9000 -80800CI-4450-56000-Serisi Modellerinde
    Menü Sistem Ayarları üzerinde 121 tuşlayınız ve açılan menüden Etid Code bölümüne giriniz kumanda üzerindeki kırmızı tuşa basarak Biss şifreleme sistemine giriniz ve ilk satır üzerinde kumanda üzerinden ok tuşuna basarak şifreyi giriniz. ( Son yazılım yüklü ise Menü sistem ayarları üzerinde 121 tuşlayın açılan menüden Set to default seçeneğine tıkladığınızda ***ler yazılı olarak gelecektir )
    70500-74000-76000-76500-76100-74200-50200-50300-50400-50800 Modellerinde
    Kumanda üzerinden Menü 8282 tuşuna basınız açılan *** menüsünden Satır seç seçeneğinde kumanda üzerinden ok tuşuna basınız sağ sol tuşlarını kullanarak biss bölümüne geliniz ve herhangi bir satır üzerinde ok tuşuna basarak şifreyi giriniz.
    8000 Serisi Modellerde
    Kumanda üzerinden menü 9317 tuşlayınız ve açılan *** menüsünden kumanda üzerindeki menü tuşuna basınız açılan şifreleme sistemleri menüsünden Biss şifreleme sistemini seçiniz açılan menüden herhangi bir satır üzerinde kumanda üzerinden ok tuşuna basarak şifreyi giriniz.
    11200-11300-11400-20200-20300-20400-30300-30400-30700 Serisi Modellerinde
    Nisan 2006 yazılımını yükledikten sonra kumanda üzerinden menü 6382 tuşlayınız açılan menüden kumanda üzerindeki AUX IN tuşuna basarak ***leri resetleyiniz, daha sonra kumanda üzerindeki TV/Radyo tuşuna basarak biss şifreleme sistemi menüsüne giriniz ilk satır üzerinde ok tuşuna basarak şifreyi giriniz.
    40400-90900--40100-40200-30800-40300-40700-50100- Serisi Modellerinde
    40400FTA-40400CI-90900CI modellerinde kumanda üzerinden menü tuşuna basınız oyunlar içersinde *** Listesi seçeneği üzerinde ok tuşuna basınız açılan menüden kumanda üzerindeki sağ sol tuşlarını kullanarak Biss şifreleme sistemine giriniz. 1FF9 satırı üzerinde kumanda üzerinden kırmızı tuşuna basınız ve *** seçeneği üzerinde ok tuşuna basarak şifreyi giriniz.
    Not : *** listesi seçeneği yok ise oyunlar içinde kumanda üzerinden 9999 tuşlarına basarak emuyu aktif ediniz.
    40100FTA-40100CI-40100SKY-40200SKY-40300FTA-40300CI-40700FTA modellerinde kumanda üzerinden menü tuşuna basınız basınız oyunlar içersinde Kod Düzenle seçeneği üzerinde ok tuşuna basınız açılan şifre menüsüne 0000 yazınız ve gelen menüden kumanda üzerindeki sağ sol tuşlarını kullanarak Biss şifreleme sistemine giriniz. 1FF9 satırı üzerinde kumanda üzerinden kırmızı tuşuna basınız ve 8Byte *** seçeneği üzerinde ok tuşuna basarak şifreyi giriniz. Gelen menü üzerinde ok seçeneği üzerinde ok tuşuna basarak kaydediniz.
    Not: Kod düzenle seçeneği aktif değil ise Menü içersinde 19370 gelen şifre menüsüne 2486 yazarak emuyu aktif ediniz.
    14200-14300-14400-14700-14900 Modellerinde
    Kumanda üzerinden menü tuşuna basınız SmartCard seçeneği üzrinde ok tuşuna basınız, açılan menüden *** Manager seçeneği üzerinde ok tuşuna basınız. Açılan menüden yukarı aşağı tuşlarını kullanarak Biss seçeneği üzerinde ok tuşuna basarak açılan menüden 000ff9 seçeneği üzerinde ok tuşuna basınız açılan menüden CW seçeneği üzerinde ok tuşuna basınız ve şifreyi giriniz.
    Not: SmartCard seçeneği aktif değil ise menü 9999999 tuşlayarak SmartCard seçeneğini aktif ediniz.
    70100-70300-70400 Modellerinde
Benzer Konular - Trt dünya kupası
  2. uydudoktoru
  5. uydudoktoru
