Two columns of categories
Konusu 'vBulletin' forumundadır ve guclusat tarafından 2 Eylül 2012 başlatılmıştır.
    Mod Version: 1.5 ,, vB Version: 4.1.x
    If you installed the mod, please "Mark as Installed".
    also, who have marked this modification as installed will receive notifications about updates.
    LATEST VERSION 1.5
    change log
    • Optimization of the code
    • No more one column with 50% width - fixed completely
    • The hack works now with categories which act as forum
    • Gap issue fixed!
    Description:
    This mod splits the categories list into two columns.
    Compatibility:
    Works with all vBulletin 4.1.X versions,
    may work with 4.x, not checked
    Installations:
    you don't have to change anything in the templates,
    just upload the plugin and that's all.
    - Import XML file (as product): AdminCP > Plugins & Products > Manage Products > [Add/Import Product]
    Settings:
    Settings -> Options -> Two columns of categories
    - Enable/Disable the hack
    - Set the margin between categories
    - Disable the hack in specific styles
    Screenshot:
    History:
    • [06-12-11] v1.0:
      First Release
      [06-12-11] v1.1:
      Fix minor bug: the necessary css now loads only in the index
    • [07-12-11] v1.2:
      Fix bug: necessary css now work for who choose save css as files
    • [08-12-11] v1.3:
      The hack works now with all 4.1.X versions
    • [10-12-11] v1.4:
      New Feature: Disable the hack in specific styles
    • [13-02-12] v1.5:
      • Gap issue fixed!
    Future Features (not included in this version):
    • Ability to choose which categories to split instead of all categories.
    Note:
    For those who run version 1.4 or older, and modified the css template - must revert this template.
