Ueberschall Pop Charts Elastik Soundbank 2011
Konusu 'Program Arsivi' forumundadır ve hoanghiep1123 tarafından 27 Haziran 2011 başlatılmıştır.
  1. hoanghiep1123
    Online
    hoanghiep1123 Guest
    Ueberschall Pop Charts Elastik Soundbank 2011 Ueberschall Pop Charts Elastik Soundbank 2011 [​IMG] Ueberschall Pop Charts Elastik Soundbank 2011 3.18 GB [​IMG]
      Content / Structure: Material is divided into 2 parts: Part A: The construction kits (split into intro, a-part, b-part, c-part, outro) are bursting with beats, harmonies and melodies; for high-tech pop productions. Part B: live played add-on material. The beats are divided into multi-track layers, synths, pianos, pads, basslines, guitars, percussion and effects.  Each construction kit is divided into 5 folders: 1. Complete mixes of the construction kit; intro, A part, B part, C part and outro. 2. Complete backing tracks, consisting of intro, A part, B part, C part and outro. 3. Drum mix versions of the single parts and single drum loops li-ke bass drum, snare, hh, a. s. o. 4. Instruments split up into single recording tracks. 5. Single sounds of the drum loops.  The Add-on soundbank (Pop Charts B) features a wide selection of multi purpose live material, untreated and “as recorded”. It?s easy and fun to apply these in combination with the construction kits. The Add-on sound-bank also contains drum loops, bass, guitar, piano and synth licks. The acoustic drums come as single tracks for each instrument, e.g. bass drum, snare drum top, snare drum bottom, high-hat, ride cymbal, toms, overhead mics, and room mic. An additional snare trigger track allows to easily replace snare sounds anytime. Drums were recorded without compression or other treatment and come as dry tracks to ensure maximum versatility in any project. Drum tracks have been quantized, making them perfectly compatible with each other. Bass and guitar tracks come both as a dry version, and as an effect treated version.  hotfile.com Rapidshare.com Wupload.com Uploadstation.com filesonic.com
     FILESONIC:  http://www.filesonic.com/file/1288309651/Uberschall.Pop.Charts.Elastik.Soundbank-XANEX.part1.rar http://www.filesonic.com/file/1288224004/Uberschall.Pop.Charts.Elastik.Soundbank-XANEX.part2.rar http://www.filesonic.com/file/1288224054/Uberschall.Pop.Charts.Elastik.Soundbank-XANEX.part3.rar http://www.filesonic.com/file/1288315551/Uberschall.Pop.Charts.Elastik.Soundbank-XANEX.part4.rar http://www.filesonic.com/file/1288367821/Uberschall.Pop.Charts.Elastik.Soundbank-XANEX.part5.rar http://www.filesonic.com/file/1288526231/Uberschall.Pop.Charts.Elastik.Soundbank-XANEX.part6.rar http://www.filesonic.com/file/1288517091/Uberschall.Pop.Charts.Elastik.Soundbank-XANEX.part7.rar http://www.filesonic.com/file/1288251961/Uberschall.Pop.Charts.Elastik.Soundbank-XANEX.part8.rar
    if you do not want to wait that long I suggest you use 30-day package. work your use will become easier. [​IMG] thank you very much!
Benzer Konular - Ueberschall Pop Charts
  1. forumvakti
