Use Google Custom Search In Navbar
Konusu 'vBulletin' forumundadır ve guclusat tarafından 9 Eylül 2012 başlatılmıştır.
    Mod Version: 1.00 ,, vB Version: 4.2.x
    This mod will replace vb search in navbar with google custom search.. you can still use advance search from navbar. google search provide much better result when you try to search word under 4 letters..
    1. First download google.php upload in your forum root
    2. Go to your AdminCP Go to Styles & Templates -> Style Manager
    select Style then click Create New Template rename Template to GOOGLE
    Paste this code in google Template :
    PHP:
    {vb:stylevar htmldoctype}
    html xmlns="http://www.w3.org/1999/xhtml" dir="{vb:stylevar textdirection}" lang="{vb:stylevar languagecode}" id="vbulletin_html">
    head>
    title>{vb:raw vboptions.bbtitle}</title>
    vb:raw headinclude}
    head>
    body>
    vb:raw header}
    vb:raw navbar}
    div id="pagetitle">
    h1>{vb:raw pagetitle}</h1>
    div>
    h2 class="blockhead">Google Custom Search</h2>
    div class="blockbody">
    div class="blockrow">
    div id="cse-search-results"></div>
    script type="text/javascript">
      var
    googleSearchIframeName "cse-search-results";
      var
    googleSearchFormName "cse-search-box";
      var
    googleSearchFrameWidth 800;
      var
    googleSearchDomain "www.google.com";
      var
    googleSearchPath "/cse";
    </script>
    <script type="text/javascript" src="http://www.google.com/afsonline/show_afs_search.js"></script>
          </div>
        </div>
        {vb:raw footer}
      </body>
    </html>
    3. Then Open Navigation / Breadcrumb Templates Click Collapse button click navbar Template find
    PHP:
    <div id="globalsearch" class="globalsearch"
    and
    PHP:
    <ul class="navbar_advanced_search"
    remove all code between this with
    PHP:
    <form action="http://www.mobilephonetalk.com/google.php" id="cse-search-box">
    input type="hidden" name="cx" value="partner-pub-8038994048300561:7c8fy7cujxg" />
    input type="hidden" name="cof" value="FORID:9" />
    input type="hidden" name="ie" value="ISO-8859-1" />
    span class="textboxcontainer"><span><input type="text" value="" name="q" class="textbox" /></span></span>
    span class="buttoncontainer"><span><input type="image" class="searchbutton" src="{vb:stylevar imgdir_button}/search.png" name="sa" onclick="document.getElementById('navbar_search').submit;" />  </span></span>
    form>
    script type="text/javascript" src="http://www.google.com/cse/brand?form=cse-search-box&amp;lang=en"></script>
    Note : Replace
    PHP:
    with your won website name
    Replace
    PHP:
    with your won adsense code..
    • google.zip
      google.zip
      Dosya Boyutu:
      814 bayt
    Son düzenleme: 9 Eylül 2012
Benzer Konular - Google Custom Search
