vBulletin Doublepost Prevention
Konusu 'vBulletin' forumundadır ve uydudoktoru tarafından 26 Ocak 2012 başlatılmıştır.
    vBulletin 4.x Version ::::: Mod Version: 4.1.7.0
    ** Due to CKEditor & Autosave, This is only compatible with vBulletin 4.1.4 onwards **
    Please remember to click Mark as Installed if you use this modification.
    Please fee free to nominate this modification for the MOTM, and/or use the donate link provided (Support Developer).
    This is a current version of the popular modification, originally developed for the early 3.x series by Xenon.
    Basically, if member posts in a thread where they were the previous last poster, then if the conditions are met, their new post will be auto-merged into the previous post instead of creating a new "double" post.
    A number of options are provided ;
    Time Limit - if more than xxx minutes have passed since the last post, no merge is done.
    Timestamp Spacer - if enabled, a timestamped spacer is added between the old post text and the new post text.
    Other spacer choices provided are no spacer, a default, or a custom spacer.
    Spacer Colour - allows you to set the colour of the spacer between merged posts (if one is enabled).
    Post Timestamp Update - if enabled the newly merged post will have its post time updated to the new time, otherwise it retains the time of the original post.
    Usergroup exceptions - Allows you to exempt certain usergroups from the doublepost merges.
    Forum exceptions - Allows you to exempt certain forums form the doublepost merges.
    IP Address Check - Specifies if the poster IP should be checked, if enabled, the post will only be merged if the user and ip address are the same.
    All settings are located in vBulletin Options > Doublepost Prevention.
    To install just unzip the XML and import into vB using the ACP Product Manager.
    Support
    Support will not be provided for vBulletin 4 Alpha, Beta or RC versions.
    Low priority will be given to posters who do not have this marked as installed
    In some cases, support can only be provided if I have an admin login and ftp access.
    History:
    v4.0.1 : 15-Jan-2010 : Initial release for vb 4.0.0 Gold.
    v4.1.0 : 04-Dec-2010 : Updated for vBulletin 4.1.
    v4.1.1 : 17-Jun-2011 : Fixed for vBulletin 4.1.4.
    v4.1.2 : 30-Jun-2011 : Javascript updated for CKE and Autosave.
    v4.1.3 : 08-Jul-2011 : Dependancies updated as its no longer compatible with vB 4.1.3 or less.
    v4.1.7.0 : 16-Oct-2011 : Updated for vBulletin 4.1.7.
Benzer Konular - vBulletin Doublepost Prevention
  3. uydudoktoru
