VU Meter 1
    It is a simple circuit of optical index of level of sound signals, adapted in various needs of user. It can be adapted in various levels of entry, regulated from trimmer TR1 (Level) - TR2 (Gain), then it is rectified by the D1-2 (cutting off of negative periods of signal-rectification) and drived to the main circuit of index, that it is constituted by D3...D13 , the transistors Q2-Q13 and the materials that exist around them. The optical index him we take from the line of LED LD1-13. The each led turns on when the level is altered at 0,65V roughly. The requirements in current are 100 ma with complete index. We can add all units LED we want, always calculating the current where they will need the news LED. [TABLE="width: 100%"]
    Part List (Malzeme Listesi)
    R1=47Kohm
    R24-26-28-30=4.7Kohm
    R2-3 =1Mohm
    TR1=100Kohm Trimmer
    LD1-7=LED Green
    R4-R7=1Kohm
    TR2=4.7Kohm Trimmer
    LD8-10=LED Yellow
    R5=100ohm
    C1=10uF/25V
    LD11-13=LED Red
    R6=18Kohm
    C2=100nF/100V MKT
    D1-13=1N4148
    R9-11-13-15-17=560ohm
    C3=4.7uF/25V
    Q1 ....Q13=BC550C - BC549B
    R19-21-23-25-27=560ohm
    C4=4.7uF/25V
    IC1=TL071
    R29-31=560ohm
    C5=10uF/25V
    IC2=7812 [With Heatsink]
    R8-10-12-14=4.7Kohm
    C6=47uF/25V
    R16-18-20-22=4.7Kohm
    7-8=100nF/100V
    All Resistors is 1/4W 1 -5%
    Son düzenleme: 30 Mayıs 2016
