Wideband DTV UHF Antenna TV Amplifier Circuit using transistor 2sc3358 – Antenna amplifier for digit
uydudoktoru
Yönetici
Yönetici
This HD TV UHF wideband amplifier(Ultra High Frequency amplifier) has a total gain of 10 to 15 dB in the 400 – 850 MHz domain frequency so it can be used where the tv signal is weak.
For this UHF antenna tv amplifier to work correctly you need to cut the components pins as short as possible. C1, C2, C6, C7 are SMD type ( surface mounted ). This antenna tv amplifier or uhf wideband amplifier need to be build inside of a metal box and then connected close to the tv antenna.
Prototype pictures (Prototip resimler)
Antenna HD TV UHF band amplifier circuit schematic (Anten HD TV UHF bandındaki amplifikatör devre şeması)
PCB layout for Wideband HD TV UHF Antenna TV Amplifier Circuit using transistor 2sc3358 (Baskı Devresi)
The power supply is a simple 12V stabilized source. The antenna tv amplifier can be connected directly to the power supply thru coaxial cable of the tv antenna but you need a 10 – 100uH coil on the alimentation line. The tv set will be connected to the uhf amplifier thru a small coupling capacitor.
Adjusting is easy, just bring the P1 to the middle and then adjust it untill you obtain the best tv image quality.
Digital Tv antenna UHF amplifier components (Devrede kullanılan malzeme listesi):
  • T1 -Transistor 2sc3358
  • C1 – 10µF/35v
  • C2,C9 – 1nF
  • C3 ,C4 – 10nF
  • C5,c6,c7,c8 – 10pF
  • R1 – 470 Ohms
  • R2 – 2.2 K
  • R3 – 1Kohms
  • P1 – 5Kohms
  • L1,L2 – 2 turns 22AWG , 3mm Ø.
  • L3,L4 – 10uH or 10 turns, 0.2mm Ø on ferrite..
  • 12 volts special power supply.
2sc3358 Transistörü kullanılarak Geniş Bant DTV UHF Anten TV Amplifikatör Devresi
