WiFi Slax Wireless Hacking Live-CD v3.1 + Plugins Updated
Konusu 'Program Arsivi' forumundadır ve hoanghiep1123 tarafından 27 Haziran 2011 başlatılmıştır.
  1. hoanghiep1123
    hoanghiep1123 Guest
    WiFi Slax Wireless Hacking Live-CD v3.1 + Plugins Updated WiFi Slax Wireless Hacking Live-CD v3.1 + Plugins Updated [​IMG] WiFi Slax Wireless Hacking Live-CD v3.1 + Plugins Updated 635.24 MB [​IMG]
      Basic Directions: 1)Boot from cd 2)Get the wep key 3)Write it down 4)Reboot into windows 5)Connect using wep key.  WEP is an encryption scheme, based on the RC-4 cipher, that is available on all 802.11a, b and g wireless products. WEP uses a set of bits called a key to scramble information in the data frames as it leaves the access point or client adapter and the scrambled message is then decrypted by the receiver. Both sides must have the same WEP key, which is usually a total of 64 or 128 bits long. A semi-random 24 bit number called an Initialization Vector (IV), is part of the key, so a 64 bit WEP key actually contains only 40 bits of strong encryption while a 128 bit key has 104. The IV is placed in encrypted frames header, and is transmitted in plain text.  Traditionally, cracking WEP keys has been a slow and boring process. An attacker would have to capture hundreds of thousands or millions of packets? a process that could take hours or even days, depending on the volume of traffic passing over the wireless network. After enough packets were captured, a WEP cracking program such as Aircrack would be used to find the WEP key.  hotfile.com Rapidshare.com Wupload.com Uploadstation.com filesonic.com
     FILESONIC:  http://www.filesonic.com/file/1288443974/WiFi_Slax_Wireless_Hacking.rar
    if you do not want to wait that long I suggest you use 30-day package. work your use will become easier. [​IMG] thank you very much!
