WRF-150A 150 Watt RF broadband amplifier FM (75MHz-110MHz)
1, uses:This product is mainly used for FM broadcasting equipment production and assembly.
2, performance characteristics:
  • The entire plate using double-sided high-frequency red epoxy PCB. High-frequency characteristics of superior aesthetic appearance.
  • Motherboard structure that contains the RF amplifier, low-pass filter circuit, VSWR protection circuit, power conversion circuits.
  • RF amplifiers from RD15HVF1 and SD2931-10 component. Amplifier input power 1W, power amplifier after the filter output 150 watts.
  • Expansion functions: reflection power, positive power, VSWR protection switch, power switch.
3, main technical parameters:
  • Supply voltage: 48 ~ 50V
  • Electric current : < 6A
  • Frequency Range: 75MHz ~ 110MHz (MAX: 50 ~ 110Mhz)
  • Bandwidth: 35MHz
  • Input power: ≤ 1 Watts, 1.5 watts maximum input
  • Output power: 150 watts (adjust input power, output power can change the size).
  • Harmonic Suppression: -65 dB
  • Flatness: <1 dBm
  • Working temperature: -20 ℃+50 ℃
  • Work: 7 days 24 hours of continuous work
  • Unit dimensions: long 18 CM ,wide 10 CM ,Thick 1.5 CM。
  • Products using the documentation(PDF file Click to download)
Ekli dosyalar
