FrozenPlain Phoenix v2.0 KONTAKT
Konusu 'Program Arsivi' forumundadır ve BaDshaH tarafından 1 Aralık 2018 başlatılmıştır.
  1. BaDshaH
    BaDshaH Banned
    26 Kasım 2018
    FrozenPlain Phoenix v2.0 KONTAKT | 244 Mb
    Phoenix is a powerful tool for creating string and choir sustains with movement and character. The samples are from synthetic and granulised sources, yet they are rich and organic sounding. The presets vary from realistic strings and choirs to sci-fi beeps and pads. This versatility is due to some unique scripting, such as the LFO engine; which lets you draw your own waveforms and actually see the modulation happen on the controls.
    Phoenix is a Kontakt library designed to be a tool for making rich pads using strings and choirs. There are 6 oscillators which can be mixed, tuned and panned. Each of these layers are great sounding by themselves, but when layered properly can create rich tones. On this first page are also 2 ADSR envelopes, for the volume, and low pass filter.
    Movement is key when making sustained instruments, and this is where Phoenix excels. The unique LFO engine allows easy modulation of virtually any parameter. The shape of this oscillation can be drawn by you and the results are actually shown on the control that you have chosen (such as cutoff frequency or layer 3 volume). Up to 4 parameters can be modulated at once.The second page of Phoenix is the FrozenPlain Effects Engine v2.0, this contains 13 effects such as reverb, phaser, chorus, echo and more. Though powerful, Phoenix can be light on your CPU and RAM. For example, each effect will be bypassed when not in use. You have the ability to purge unused samples from RAM by shift-clicking on the activate buttons on each layer. The UI for Phoenix is very simple, and to get you started are 12 presets.
    Features:
    • Smooth and rich synthesiser samples
    • 6 layers or 'oscillators' which can be mixed, tuned and panned
    • ADSR and velocity controls for volume and low pass filter
    • 2 custom LFOs - draw your own waveforms and see the modulation happen
    • Phoenix can create everything from realistic string ensembles to sci-fi beeps and pads
    • FrozenPlain Effects Engine v2.0
    • 12 presets
    Download From UploadGig
    https://uploadgig.com/file/download/4e51E905a64469ad/BaDshaH_FrozenPlain.Phoenix.v2.0.rar
    Download From Rapidgator
    https://rapidgator.net/file/d235b76f0ea656d53f4a3b3411b70d12/BaDshaH_FrozenPlain.Phoenix.v2.0.rar.html
