W. A. Production Puncher v1.0.1 WiN OSX
Konusu 'Program Arsivi' forumundadır ve BaDshaH tarafından 1 Aralık 2018 başlatılmıştır.
  1. BaDshaH
    BaDshaH Banned
    26 Kasım 2018
    W. A. Production Puncher v1.0.1 WiN OSX | 9 Mb
    Puncher is a Multi-FX plug-in that will add instant power and punch to your tracks. In terms of compression, this is the all in one tool you've been dreaming of. Packed into its compact design you will find 3 different effects. A Transient Shaper, Multiband Compressor and Parallel Compressor. It allows you to combine the power of these 3 amazing tools to create a brand new, unique and powerful sound. Puncher not only allows you to to control the amount of the applied effect, it also allows you to control the effect itself. Offering advanced options for each effect you can fine tune every aspect as much as you like. Inside Puncher you will also find 48 configured presets made for various genres and instruments.
    Puncher is designed to give you absolute tonal control of transient energy so that you can customize and shape those sounds. Rather than have 3 separate units, Puncher has the 3 elements you need to give your mix that clear extra punch, all in one compact plugin.
    Transient Shaper
    The 'Transients' section lets you shape the transients and sustain of your tracks. The main mix control lets you set the intensity of the effect, while the advanced settings give you control over the stereo linking, bandwidth and envelope length of the detection signal, as well as the maximum boost overage or cut that you want to apply to your signal's transients or sustain.
    The 'Multiband' section divides your track into 4 bands with subtractive IIR filters, creating a real-time linear phase Multiband split. Every band has its own compressor that applies logarithmic attack and release directly to the required gain reduction value, instead of to the detection signal, smoothing out the compression effect in an analog fashion.
    Parallel Compressor
    The Parallel section lets you apply smooth parallel compression to even out the dynamics in your track in a very natural way, or create a powerful compression effect. You can also reduce the dynamic range without reduction to the peak level. The compressor has a continuous RMS time control and a knee width control that will let you fine tune the compressor's sensitivity to react aggressive and digital, or silky and analog. By adding a parallel compressor to work with the Multiband band compressor this increases the effective compression ratio and makes the processing more obvious and effective.
    Features:
    • Attack and release transient shaping
    • Real-time linear phase Multiband compression
    • Variable RMS parallel compression
    • Build in preset manager
    • Before/after dynamics wave display
    • Smoothed out bypass controls
    Download From UploadGig
    https://uploadgig.com/file/download/b922427035594373/BaDshaH_W.A.Production.Puncher.v1.0.1.WiN.OSX.rar
    Download From Rapidgator
    https://rapidgator.net/file/020bce2536fd0847d645b25fe0e388ed/BaDshaH_W.A.Production.Puncher.v1.0.1.WiN.OSX.rar.html
Benzer Konular - Production Puncher WiN
  1. BaDshaH
  2. BaDshaH
  3. BaDshaH
  4. BaDshaH
