Windows 10 Enterprise v1909 Build 18363.720 (x64) Integrated March 2020
Konusu 'Program Arsivi' forumundadır ve LoriYagami tarafından 22 Mart 2020 başlatılmıştır.
  1. LoriYagami
    LoriYagami Yeni Üye Kayıtlı Üye
    25 Kasım 2018
    Provider: Lori.Yagami
    OS : 64 bit | Language : Russian / English | File Size : 4.82 GB
    The original image from Microsoft Windows 10 1909 x64 was used as the basis for this assembly. Integrated updates available on March 20, 2020, build increased to 18362.720. The system interface is not changed. The necessary system libraries and programs are installed. At the initial stage, there is a choice of one of the two languages ??of the installed system. Read more below.
    Build Features:
    - To reduce the size of the image from the author's (8.44 GB) x86 bit edition was removed ;
    - The basis of the assembly image ru_windows_10_business_editions_version_1909_updated_jan_2020_x64_dvd_a4affd95.iso
    - At the initial stage, there is a choice of the language of the installed system Russian or English
    - The Install.wim file is compressed in ESD;
    - The interface is not changed. A theme was added, the system files themselves did not change or patch;
    - Integrated NET Framework 3.5;
    - Added PCM tweaks (right mouse button);
    - Integrated updates and the necessary minimum required programs of the latest versions;
    - Modified bootloader, no installation from under Windows;
    - WinPE-installer for Windows boot64.wim was built based on Win 10 1709.16299.15;
    - For convenience, the boot menu contains a set of additional utilities for working with disks / partitions, backup and recovery (all programs are integrated into the core WinPE installers).
    - There is support for loading in UEFI mode (support for loading in UEFI mode only for media formatted in fAT32 fAT32);
    - Only automatic installation is possible;
    - The system will already be activated;
    - Thanks for using the sergeysvirid � bootloader.
    Integrated:
    - uTorrent 2.2.1.25534
    - 7-Zip 20.00 alpha
    - Adobe Flash Player 32 ActiveX & Plugins 32.0.0.321
    - AIDA64 6.20.5300
    - CCleaner 5.63.7540
    - Microsoft Visual C ++ 2005/2008/2010/2012/2013/2017/2019
    - UltraISO 9.7.2.3561
    - Unlocker 1.9.2
    - WinRAR 5.80
    Treatment:
    - The system is activated AUTOMATICALLY.
    - If activation failed, then on the desktop the Help folder with activators:
    - KMSAuto Lite Portable v.1.2.2
    - AAct 3.2 DC 03/11/2017 Portable
    System requirements:
    - Processor: 1 GHz and higher
    - Memory: 2 GB RAM
    - Disk space: 20 GB
    Buy Premium Account From My Download Links & Get Fastest Speed.
    https://uploadgig.com/file/download/0c9f4493717abdF3/Bkp.LORIII.part3.rar
    https://uploadgig.com/file/download/D8beE21c60e5f3f1/Bkp.LORIII.part2.rar
    https://uploadgig.com/file/download/064bcE5Fe4eEA88d/Bkp.LORIII.part1.rar
    https://uploadgig.com/file/download/8a335Af77A653160/Best.Lori.rar
    https://rapidgator.net/file/6299f0bbfd11df49d06f8f2af06f7db1
    https://rapidgator.net/file/4e8af00a419d66df1ee269b1c2d30fe3
    https://rapidgator.net/file/b482589997236930546c2e188c89d5e4
