PHP Advanced Transfer Manager rss.php Ayarları nasıl yapılır görsel anlatım
Konusu 'Görsel ve Resimli Anlatımlar' forumundadır ve guclusat tarafından 30 Eylül 2010 başlatılmıştır.
    HTML:
    <?php
    *                               rss.php
    *   begin                : 11/09/2007 19:54
    *   copyright            : ('C) 2007-2008 TerrorLine.de
    *   contact              : http://flavaclown.de/contact.php
    *   $Id: rss.php, v1.05 10/06/2008 22:24 Flava Clown $
    *   This program is free software; you can redistribute it and/or modify
    *   it under the terms of the GNU General Public License as published by
    *   the Free Software Foundation; either version 2 of the License', or
    *   ('at your option) any later version.
    define('IN_PHPATM', true);
    $include_location = dirname($_SERVER['SCRIPT_FILENAME'])."/";
    include($include_location.'include/conf.php');
    include($include_location.'include/common.'.$phpExt);
    // config part of the script
    $site_title = $page_title; // your site title, the default setting will show what you have set in the conf.php
    $site_link = $installurl = "http://guclusat.gu.funpic.de/"; // a link to your site, the default setting, links to your phpatm powered site (absolute url).
    // $site_link = "http://guclusat.gu.funpic.de/"; // set it like this, if you don't want to use a link to your phpatm powered site.
    $site_description = "A description of my phpATM powered site."; // a description of your phpATM site.
    $max_last_files_rss = 10; // Max number of files listed, works like $max_last_files from the conf.php
    $hide_these_dirs = ""; // here you can add the names from folder which content you don't want to appear in the feed
    // an example: to hide the folders with the names 'wallpaper' and 'misc' you have to set it like this:
    // $hide_these_dirs = "^wallpaper$|misc$";
    // to hide a subfolder (like 'test' in the folder 'wallpaper') add only '^test$' not 'wallpaper/test$' !!!
    // end config part
    if (!function_exists('allhtmlentities'))
        function allhtmlentities($string)
            return preg_replace('/[^\x09\x0A\x0D\x20-\x7F]/e', '"&#".ord($0).";"', $string);
    // Ricerca ricorsivamente i file contenuti nella directory indicata ed
    // in ogni subdirectory in essa contenuta e ritorna un array contentente
    // i dieci files pi recentri trovati fino a quel momento
    function find_last_files($current_dir, $lastfiles = array())
        global $max_last_files_rss,$hidden_dirs,$showhidden,$reserved_files,$hide_these_dirs;
        // Leggo il contenuto della directory passata come primo argomento
        $handle = opendir($current_dir);
        while (false !== ($filename = readdir($handle)))
            // Scarto i file da non visualizzare o non accettabili
            if (!eregi($reserved_files, $filename) && show_hidden_files($filename))
                // Se  una dir lancio ricursivamente la funzione
                if(is_dir("$current_dir/$filename"))
                    if($hide_these_dirs == "")
                        // Non controllo le dir nascoste
                        if (eregi($hidden_dirs, $filename) && !$showhidden)
                        { continue; }
                    else
                        if (eregi($hidden_dirs, $filename) && !$showhidden || eregi($hide_these_dirs, $filename))
                        { continue; }
                    $lastfiles = find_last_files("$current_dir/$filename", $lastfiles);
                    continue;
                // Inserisco il file trovato nell'array
                $file_modif_time = filemtime("$current_dir/$filename");
                $lastfiles["$current_dir/$filename"] = $file_modif_time;
        closedir($handle);
        // Ordino l'array trovato in base alla data d'invio e
        // mantengo solo i primi '$last_files_shown' valori (definito in conf.php)
        arsort($lastfiles, SORT_NUMERIC);
        array_splice($lastfiles, $max_last_files_rss);
        return $lastfiles;
    // Stampa l'elenco dei file ordinati
    function show_files()
        global $directory,$uploads_folder_name,$installurl,$timeoffset,$phpExt;
        global $file_out_max_caracters,$comment_max_caracters;
        global $grants,$user_status,$validation_enabled,$dft_language;
        $lastfiles = find_last_files($uploads_folder_name);
        $tab = 1;
        while (list($filename, $filedate) = each($lastfiles))
            $directory = ereg_replace($uploads_folder_name, '', dirname($filename));
            if (strchr($directory, '/') == 0)
            { $directory = substr($directory, 1); }
            list($upl_user, $upl_ip, $filestatus, $contents) = get_file_description($filename, $comment_max_caracters);
            if (!$validation_enabled || $filestatus == VALIDATED || ($filestatus == UNVALIDATED && $grants[$user_status][VALIDATE]))
                $file_modif_time = filemtime($filename) - $timeoffset * 3600;
            echo"  <item>
       <title>".date("[d My] ", $file_modif_time).substr(basename(allhtmlentities($filename)),0,$file_out_max_caracters)."</title>
       <description>".allhtmlentities($contents)." Size: ".get_filesize($filename)."</description>
       <link>$installurl/index.${phpExt}?directory=".rawurlencode($directory)."</link>
       <guid isPermaLink=\"false\">".date("Y-m-d\TH:i:sO", $file_modif_time)."#".$tab++."</guid>
       <pubDate>".date("D, d M Y H:i:s T", $file_modif_time)."</pubDate>
       </item>\n";
        }             // while loop
        echo " </channel>
    </rss>";
    function show_header()
        global $dft_language,$site_title,$site_link,$site_description,$generator,$phpExt,$installurl;
        $generator = "PHP Advanced Transfer Manager v".PROGRAM_VERSION;
        echo "<?xml version=\"1.0\"?>
    <!-- RSS generated by $generator -->
    <rss version=\"2.0\" xmlns:atom=\"http://www.w3.org/2005/Atom\">
    <channel>
      <title>".allhtmlentities($site_title)."</title>
      <link>$site_link</link>
      <description>".allhtmlentities($site_description)."</description>
      <language>$dft_language</language>
      <pubDate>".date("D, d M Y H:i:s O")."</pubDate>
      <lastBuildDate>".date("D, d M Y H:i:s O")."</lastBuildDate>
      <generator>$generator</generator>
      <atom:link href=\"$installurl/rss.${phpExt}\" rel=\"self\" type=\"application/rss+xml\" />
      <docs>http://backend.userland.com/rss</docs>\n";
    header("Content-type: application/rss+xml");
    show_header();
    show_files();
    Son düzenleyen: Moderatör: 19 Şubat 2015
  2. uydudoktoru
    What it does:
    It creates an RSS Feed * with the latest files added to your phpATM page.
    * Feeds are specially formatted documents which summarize the content of web sites. For example, a feed might summarize the latest news headlines from a news site or the latest posts on a blog. You can view the content of feeds in Firefox, create Live Bookmarks for them, or add them to a feed reader on your computer or on the Web.
    How to install:
    1. Unpack the rss.php to a temporary folder.
    2. Open the rss.php with your favorite PHP editor (such as Notepad++) and change the variables from the part marked as "config part of the script" (line 28 - line 40), to fit your needs.
      1. $site_title: the title of your site (default $page_title which is the title as set in the conf.php)
      2. $site_link: link to your site (default $installurl which links to your phpATM page)
      3. $site_description: add there a description of your phpATM page
      4. $max_last_files_rss: this is the maximal number of files listed (default 10)
      5. $hide_these_dirs: hidden directories (regular expression) which latest files won't be listed (default "")
    3. Upload the rss.php to your phpATM folder. If necessary change the extension.
    4. Open the include/functions.php with your favorite PHP editor and search for function page_header($title)and find there the following line:
      HTML:
      echo "<link rel=\"stylesheet\" href=\"styles.css\" type=\"text/css\">";
      add under it the following code:
      HTML:
      echo "<link rel=\"alternate\" href=\"rss.php\" type=\"application/rss+xml\" title=\"RSS 2.0\">";
    5. You could add a link to the rss.php, a good place would be in the row where the [Last uploads] - [Top downloads] links are placed. To add it there open the index.php and search for function list_dir($directory) find there the following lines:
      HTML:
      <td align=\"center\" bgColor=\"$tablecolor\">
      <font size=\"2\" face=\"$font\" color=\"$normalfontcolor\">
      [<a href=\"showrecent.$phpExt?".SID."\">$mess[199]</a>]
      [<a href=\"showtophits.$phpExt?".SID."\">$mess[200]</a>]
      </font>
      </td>
      replace these lines with the following code:
      HTML:
      <td align=\"center\" bgColor=\"$tablecolor\"><font size=\"2\" face=\"$font\" color=\"$normalfontcolor\">
      [<a href=\"showrecent.$phpExt?".SID."\">$mess[199]</a>]&nbsp;-&nbsp;<a href=\"RSS.$phpExt?".SID."\" title=\"Click here to subscribe to my feed.\"><img src=\"images/RSS.png\" border=\"0\" width=\"16\" height=\"16\" alt=\"RSS feed\" align=\"top\"></a>&nbsp;-&nbsp;[<a href=\"showtophits.$phpExt?".SID."\">$mess[200]</a>]
      </font></td>
